Global Caché - Adding & managing
Requirements:
Your Global Cache device needs to be connected (via Ethernet) to the same home router as Zipato Controller so that they are both (should have an IP address within) in the same network.
How to add/join iTach | Global Caché device?
1. Start inclusion of iTach Flex on Zipato controller via "Add new device" button
2. Find "Global Caché" brand/logo
3. Select iTach in the "Add new device wizard"
4. Wait for the wizard to find and include your device
5. At the end automatic synchronization of data between your Zipato Controller and Zipato Cloud Server will be done
6. Device will be visible in "Lights and Power" section and in Device Manager
Learning IR code:
1. Go to "Lights and Power" section and find your iTach device (default name "IR Control")
2. Click on settings for this device
3. Click on configuration tab
4. Type in the name for the event
5. Click on Learn button
6. Take for example IR remote controller and bring it closer to iTach and press on the button of the IR remote controller you want learn over iTach
7. You will get message "New code learned successfully"
8. Click on Save button
Saving IR code:
5. Click on Set code button
6. In "Set code" window put in the IR code you want to save, press OK and confirm via Save button
7. You will get message "Code saved successfully"
Sending IR code:
2. Click on Send command button
3. In "Send command" window put in the IR code you want to send, press OK in wizard and confirm via Save button
4. You will get message "Code sent successfully"
Video Tutorial:
