How to access your SD Card on your Zipatile
Components
- Zipato Zipatile Controller
Process:
  • 1. The SD Card slot is located on top of the Zipatile, above it's internal camera
  • 2. When you put your SD Card into it, you'll have an access to it through File Manager
  • 3. Access File Manager, and go to the left top corner to select Removable SD Card
  • 4. You are now accessed your SD Card successfully
  • 5. Now you can move, copy, rename, etc. your files
  • 6. When you are done with everything, simply go to settings--> storage-->unmount SD Card
*NOTE: Zipatile supports 32 GB SD card, speed class from 2-10
