How to add DoorBird to ZipaTile
Components
- Zipato Zipatile Controller
- DoorBird 101
Process:
  • 1.) Please make sure you have firmware 1.2.15 or higher
  • 2.) Go to device manager, and add new device
  • 3.) Select DoorBird and choose right device
  • 4.) Enter the credentials that you got with DoorBird
  • 5.) After you added credentials start scan
  • 6.) The discovery of DoorBird might take couple of minutes
  • 7.) When DoorBird is found, please stop scan, and press SAVE next to DoorBird
  • 8.) Exit device wizard window
  • 9.) Synchronize controller and refresh device page
  • 10.) DoorBird is now ready for use
  • 11.) If you enter the wrong username and password
  • 12.) Go to DoorBird settings, press on configuration, and type the correct username and password
  • 13.) After you're done, press SET CONFIGURATION, and press SAVE
  • 14.) Synchronize
Video:
