Zipato Comfort Management
Climate control
Weather you are using touch panel, web interface or mobile phone, Zipato allows you easiest and most advanced way to control heating, cooling and humidity for every room in your home.
Lighting control
Easy way to save energy and make the perfect ambiance in every room:
- Experience hands-free illumination when entering a dark hallway; motion sensors can turn lights on and off, as you walk.
- Turn the whole house off in one touch with a "Good Night" scene - some lights can go completely off as the kids' dim to 10
- Program your lights to turn off automatically when a room is unoccupied for a certain amount of time
- Set your lights to a maximum level of 80%; your eyes won't notice the difference but your utility bill will!
Scenes
Adjust everything in your home by a simple click on the button.
Combine several commands into one button so that you can create the exact mood or environment with one button press. For example, a “Welcome Home” scene can create an exact environment with evening lighting, floor heating, music and blinds all adjusted to your desired settings. Tie that scene to the “Alarm Disarming” event just for the hours 5.00-9 .OOpm and you don’t even need to press a button when you come home.
Schedulers and Timers On-line
Easy on-line tool allows complete customization of home system.
Use advanced scheduler to think and do things instead of you. Any series of commands can be easily programmed with a timer function. You can decide when those events will be run. An "Evening Lighting" home timer might lower the blinds, adjust the floor heating and turn on the garden and entry lighting. This timer can be adjusted by the home owner to run at 4.30pm in winter and 7.00pm in summer. Or simply set the timer to a given time before sunset so the timer automatically follows the seasons.
Comfort Features
Full comfort for you and your entire family!
With Zipato you can remotely control and automate lighting, heating, air-conditioning, shades, home appliances, curtains, irrigation, home entertainment..., in fact almost anything in your home. You can easily automate your home to save energy and become more comfortable.
Features:
- full control from one place
- control your lights and shades from the one place
- welcome scenario when coming home
- goodbye scenario when leaving your home
Connect everything
Zipato connecting and simplifies all the technology in your home offering the ultimate lifestyle of comfort and convenience. It eliminates the need to walk from room to room to adjust drapes, lights, temperature, and audio/video components.
Full control, anywhere, any-time
Whether from an easy-to-use colour touch panel, Internet or your mobile phone, or manually like you do it now, total control is always at your fingertips, wherever you are.
Easy programming
Automate everything you want in your home by using our fun and easy on-line automation tool. Set your own rules, schedules, conditions and have fun by dragging intuitive puzzles over your screen.
