Time rule
Jan Krcmar shared this question 6 years ago
Hi I need help or advice.
I need create rule,
where Shitch will work 15min before sunset and end after 15 after sunset,
second time is switch on 6am and stay on while dont come sunrise time . If sunrise is before 6am don switch on.
I try it few times but I cant find way whitch buble are correct together when I want work with time.
If you have any advance Manual to rules and bubles, or way how to see what time is set from this plus minus operation
pls send me
Replies (7)
0
there are a lot of manuals and videos online.
Also our community gives a lot of advice in our topics so you could search them.
You can check our Youtube channel ZipatoTV
https://www.youtube.com/user/zipatotv/search?query=rule+creator
Also in our community there are similar answers with your question.
https://community.zipato.com/topic/rule-with-between-time-run-only-in-sat-sun
Also here:
https://community.zipato.com/topic/zipabox-rule-creator-manual-
Best regards
I watched them all, they are useless for me in this case.
I tried to find it on community and I havent found what I need.
Also here:
404 ErrorPage not found or moved!
I need some advance manual , or way how to see real-time what will be set for next day or way witch I can use for debuging rules.
I found few ways how some rules can be debuged by sending notification,
but when I try to set time, It shows me syntax error, so I need to know What I can Use
3
The best is to post your rule so that the community can help you by correcting it.
here is a beginning of your rule for what I understood:
/x+PyPBR6xjV7QAAAABJRU5ErkJggg==
post your rule screenshot here maybe the whole community can help.
Jan,
I agree, you should post your rules so we can help you more specifically. Find attached the guide I created, this is one of the most recurrent topic's subjects, schedulers and how to use astro function, use astro offset as Stillwatter recommends.
Our professional writers across 50+ academic fields and https://topessaybrands.com/review/kibin/ subject matters hold relevant Master’s and Ph.D. degrees to fulfill your assignments from the ground up and by the textbook.
I am very impressed with the information you shared. I have learned many interesting things from your post and I will definitely follow your next posts. suika
