Rule - Start at sunrise but not before defined time
Guest shared this question 6 years ago
I want to create a rule which open my roller shutters (Fibaro) at sunrise, but not before 08:00am.
So, if sunrise is at 08:30am, the roller shutter should open at 08:30am. But if sunrise is at 07:00am, the roller shutters should open at 08:00am.
I can create a rule only with the trigger "sunrise", or with the trigger "08:00am", but not with a combination of both.
Can sombody help or givea hint?
I would make 2 sensors: one sunset-dawn, switching by the sunset scheduler, the second, for example, day-night, switched by the scheduler in time. Then the following rule: when switching any of the sensors, if both sensors are active - open the stings...
Replies (6)
No ideas? :-(
I think you should be doing test with the > puzzle and compare the times between the actual sunrise and the specified hour.
hello, it's possible like that.
Two rules.
1. Triggers at sunrise. If time >= 8:00, open blinds
2. Triggers at 8:00. If sunrise < 8:00, open blinds
You could use variables as well. See attachment
