Using the same sensor in multiple Virtual Alarms, does it work properly?
Alberto Macias shared this question 7 years ago
I have read that there was some issues while trying to use the same sensor on multiple alarms, does anyone knows if this is working good now??
If I understand well you ask if a device sensor can be used in several partitions alarms ?
Personally I have that configuration and it run. But perhaps it is non recommended.
Dear Alberto,
There are no issues if you are using the same sensor in multiple Security partitions.
Pero
Ok, I will give it a shot.
