Siren device not showing in Alarm configuration
Ian Byles shared this problem 7 years ago
Hi ,
I've added a Fortezz alarm (SAA 03) as a siren device and its working ok. However, I can't see it in the select siren list in the Alarm configuration. I've tried various "Show As Device" options but can't get it to work.
Ian
When I look at that siren, it shows a slider bar and percentage.......... seems like it has not been included properly and somehow shows as a dimmer device....?
Yes, good thought. Try to remove, reset and reinclude.
HI Thanks,
I'll try and reset. but I believe it is a multilevel device, thats why its been included with a slider bar, can this be changed?
From the Fortress manual:
Controlling the SSA3 (MultiLevel Switch Command Class or Basic Command Class)
If a Z-Wave MultiLevel Switch Set or Basic Set signal with a value of 67 to 99 or 255 is received by the SSA3, the unit
will sound a 120-decibel audible alarm and will flash the strobe lights. A value of 1 to 33 will turn on only the strobe
lights while a value of 34 to 66 will turn on only the siren. The same messages with value 0 will turn off both the siren
and strobe lights.
I'll let you know how it goes after the weekend.
Ian
I've got around the problem by setting up a virtual switch that does show as a siren, then use rules to turn the real siren on and off.
