doorbird integration question
Chris Gen shared this thanks 3 weeks ago
I have a doorbird a zipatile and a zipabox I would like to setup my zipatile to be able to get my ring on the zipatile when somebody ring or a movement is detected and automatically open the app and show on screen is it possible?
I would like also to setup the sip between zipatile and the doorbird how to do it ?
thanks in advance
Comments (2)
no body know ? of popup the doorbird app when sombody in calling ? or a movement is detected by the doorbird ?
Hi. You dont need SIP. Basically on the web UI you should go to the doorbird device settings and ensure that the bell press action "OPEN APP" is selected. You should also go to the camera settings and insert your login details. At least for me when integrating doorbird, I had to add the login details to the camera settings anyway.
You should then install the doorbird app on zipatile and insert user.
It should work.
