I can't register RFID to my Mini Keypad
Henrik Møller-Jørgensen shared this thanks 1 month ago
When I'm using the learn mode it doesn't react. it just times out allthough I press the Away buttom on the mini keypad and then take the RFID and press it to the mini keypad and get the signal and led
Comments (5)
I just did on mine, but i think you should use Home button when learning?
Hi Mattias
I have tried using the Home buttom as well, it still just timeout
1. Try to sync your devices before learning a tag.
2. Try to assign a code instead of learning a tag, then switch back to learning a tag.
Exactly that was what i did, also had issue. Then assigned a code and then tried learning tag again.
All I can think of is a defective/non compatible tag or a tag that has already being learnt and assigned.
