Keypad arm/disarm ignored by system
kotobelo shared this problem 7 years ago
I have a problem making the keypad arm/disarm the system. I dont know what else to do, as I have already:
- Added as a new device
- Configured device (User Entry Keypad) with a pin code (learn mode: Home + 4digits + Enter)
- I have only one user account that is the master
- I have only one security partition configured as quick arm
- I have configured in the security partition the user master to be able to use the PIN AWAY and PIN HOME to Arm and disarm respectively.
- I have synchronized with the controller .
Now when I type in the keypad: AWAY + Pin code + Enter the security partition state remains disarmed.
I have configured other devices (remote control) to arm the alarm so, I am not sure why the command from the is not taken into account.
Could it be that the code is not successfully learnt?
I have already replaced one keypad by a new one and still the same problem. Please, I need some help, if I dont get this keypad to work, I will need to replace the entire system.
Thanks.
Hello Kotobelo,
please, upgrade your controller to the latest beta firmware version (Controller settings--> Firmware--> Load Beta) and re-add your keypad, this will resolve your issue.
The solution to this was as simple as installing the latest beta in the controller.
Thanks to Zipato for the quick support.
I have my controller updated, and I made the same steps above. But when I arm Away or dissarm Home in the Keypad, the alarm does nothing, it keeps dissarmed or armed without any change.
Do I have to do any other step that I don't know?
Thank
