Z-WAVE NETWORK MANAGEMENT -
Magnus shared this question 9 years ago
Please explain:
What is NETWORK HEAL and what function? Same question with HARD RESET
43SVd39OoKCek3ksNCU6
Network heal
Network heal is a tool that can rebuild the Z-Wave controller routing table of the entire Z-Wave network.
It instructs every Z-Wave device in your Z-Wave network to find other Z-Wave devices in their direct range and report the results back to the controller. With this information, the controller can construct a new routing table that reflects the current topology of your Z-Wave network.
This process can be started and stopped at any time, without side effects.
Hard reset
Hard reset will reset the Z-Wave module of your Zipato controller to its default settings.
Be aware that it can only reset the Z-Wave module of your Zipato controller, it will not affect other Z-Wave devices in your Z-Wave network.
After a hard reset, your Zipato controller will no longer be able to communicate with your other Z-Wave devices. They will no longer be shown on your dashboard.
You will have to remove and add every device again after performing a Z-Wave hard reset to control them again.
Both functions were introduced in firmware version 0.9.999.3
Replies (6)
Not supported yet I think...
Network heal
Hard reset
Is this working now?
And can I know when it is working?
did set up all wake up times to the minimum.
some direct routing slave are not displayed.
for example I got 2 fibaro motor controllers. only one is showing up.
almost all battery powered modules fail in the heal function (AEON multisensor, fibaro sensor, philio sensor)
Hmmm....where do you locate Network Heal in the GUI....?
Can't find it.....
Running on Firmware version 0.9.999.4
Never mind that....
For information it's located under Zipabox Settings (Just Scroll to the bottom and hit the button...8)
