Zipatile (Motion Sensor and Door Lock)
maurotafuro shared this thanks 4 months ago
I'd like to know (if there are somebody which have already tested) what are best Zwave Motion Detection and Door Lock compatibile with Zipatile in order to implement rule. If it possible I'd like to know Manufacturer and Model of Zwave Motion Detection and Door Lock...
Mauro
Comments (12)
Hi Mauro,
I am attaching a list of supported devices which might be of help. These are devices that are tested and implemented.
Would be possible to have an update in that list?
Thank you
hello, I have a CoCo AMST-606 Door/Window Sensor (with stand in the Zipato list) , in combination with the Zipatile Z-wave & Zigbee,
If I open Z-wave I cannot include this, what do I wrong....???
my firmware is 1.3.14e
Hi Sheldon,
We will check what is going on with your device in a separate ticket.
BR,
Mislav
For Motion Sensors I have;
* Fibaro Motion Sensor - All seems ok, it tends to give more false alarms until configured according your application. I like the "eye" style LED.
* Aeotec MS6 - Everything is supported but the UV meter (I don't use it), i like the fact that it can be battery or USB powered. It has given me less false alarms while used in the security alarm than fibaro one.
For door locks I have three Yale locks and all functions are supported, the only thing I would like to have is the hability to disable users based on a schedule (in case you have a worker or something like that) and one-time PIN's (it gets disabled once you used it).
These are the models I have;
https://www.homecontrols.com/Yale-ZWave-Plus-KeyFree-Touchscreen-Deadbolt-Assure-Lock-YAYRD246ZW2x
https://www.homecontrols.com/Yale-Z-Wave-Touchscreen-Leverset-YAYRL220ZWx
This is the newer version, I haven't tested it but it should be the same;
https://www.homecontrols.com/Yale-ZWave-Plus-SL-KeyFree-Touchscreen-Deadbolt-Assure-Lock-YAYRD256ZW2x
Hope it helps.
Alberto Macias, thanks for the links. But i wonder which brands of doorlocks are supported by Zipato.
Hi Alberto,
regarding Yale Door Lock does it exist European Version (868.4 MHz)????
Do you know if Zipatile correctly works with Vision Door Lock? I tried to test it with Zipatile but It doesn't recognize because during inclusion process Zipatile say "Manifacturing Report don't received"..for that reason there aren't attribute for Vision Door Lock and it isn't possible to use on Home Rules!!
I think it should, if they support Z-wave they would have to have all different frequencies but you need to find a local supplier.
I'm not sure about the Vision Door Lock, but I have had that issue while including devices and I think is related to the secure inclusion recently added to Zipato controllers the way I have solved it is as follows;
* Exclusion process begins, need to wake up device to send NIF (check your manual for wake up procedure).
* Inclusion process begins, need to wake up device to send NIF
* When you get "Inclusion is in progress..." message keep waking up your device every 2 or 3 seconds so it sends NIF until you get the "Inclusion complete" message.
Perform the inclusion from the web app, not from the tile itself.
Hi Mauro,
We got it installed at our office. It works fine for us. The only thing is that we couldn't have access to users codes, etc, but open and close went quite well, even put some ID numbers.
This "Manifacturing Report don't received", i used to get it when i try to add a device too far from the controller. What i do ussually, is or reset the device, and add it close to the controller.
I installed it but Zipatile doesn't recognize attribute of Door Lock, for that reason is not possible to use Door Lock Event on Home rule, in other words if I want to power on Zwave Led when Door Lock is opened is not possible because on my Zipatile Rule there isn't any event associated to Vision Door Lock ZM1701, do you have solve that problem?
Mauro
Hi Mauro,
as soon as We have a definitive answer with a solution We will write it.
This should probably be in the next few weeks.
The door lock needs additional support which should be solved by then by our main integration engineer.
Kind regards,
Borna
Dear Borna,
when you have a definitive answer please say me
Mauro
