Firmware version 1.3.60
Firmware Version 1.3.60 [2019-03-13]
- General: added local API for /v2/systems and /v2/abilities
- General: report activeRoles of user on /v2/users/current locally
- General: added wifi scan and 3G network monitor
- General: check network online state before polling device
- General: fix for excessive reconnects when using TCP protocol
- General: disconnect heartbeat connection after redirect to another server
- General: added option to disable local API
- General: added compressed protocol
- General: added attribute filter
- General: faster start of mobile backup, force updating main server address(es)
- General: added support for 1.3 slaves in master/slave systems
- General: added option to disable server certificate validation for HTTP requests
- General: added RGBWW attribute
- Weather: made weather device go (on|off)line if there is (no)
data
- Weather: added direct Weather API support
- Weather: added Yahoo Weather
- Weather: adder Gismeteo
- Weather: added yr.no
- Weather: added OpenWeatherMap
- Weather: added SunriseSunset calculator
- Alarm: process device status updates
- Alarm: added passthrough PIN support for non-native partitions
- Thermostat: moved setmode logic from thermostat to actuator, not sending duplicate set mode commmands
- Thermostat: tracking the endpoint that caused a setpoint change to prevent multiple updates
- Zipabox2: fix for zipabox going on backup after switching from (eth+wifi) to (wifi)
- Z-Wave: do not use SUPERVISION cc by default
- Z-Wave: do not set started flag before network startup is done
- Z-Wave: report fail on inclusion if saving to cloud failed
- Z-Wave: better check for controller association when doing network heal
- Z-Wave: compare effective values for Thermostat Setpoint
- Z-Wave: association fixes, better handling of controller virtual endpoint
- Z-Wave: updated manufacturer list
- Z-Wave: poll FLIRS devices once per day by default
- Z-Wave: added discovery command to add&delete random number of virtual slave nodes to randomize node ids
- Z-Wave: don't make S0 and S2 devices go online after receiving ACK or NIF, crypto keys could be wrong
- Z-Wave: S2 inclusion
- Z-Wave: fixed S0 over S2
- Z-Wave: create S0 & S2 keys on init & hardReset instead of on networkStartup
- Z-Wave: always use the system temperature scale for multilevel sensors
- Z-Wave: added FGR222 support
- Z-Wave: use bytesize if present when sending configuration
- Z-Wave: added support for Contec DAVINCI_WALL_CONTROLLER
- Z-Wave: send duration=0xff by default for Multilevel Switch
- Z-Wave: shrunk JSON configuration for User Code Input
- Z-Wave: saving device serial, added zwDumpInfo command
- Z-Wave: correctly handling THERMOSTAT_SETPOINT_SUPPORTED_REPORT
- Zigbee: support for Philips Hue Dimmer Switch
- Zigbee: added support for Sinope devices
- Zigbee: added Hue white ambiance support
- Zigbee: support for OSRAM devices
- Modbus: fix for discovery fail if no IP connection
- Modbus: support for WebRelay X-410-E Modbus device
- Modbus: correction regarding poll timeouts
- Modbus: additional changes to error response handling, txId mismatch and connection loss
- Risco: correction regarding polling and tracing
- Risco: changed Risco Discovery procedure, zones do not need to be ordered when adding
- Lutron: fix formultiple bridges on the same Zipabox
- Enocean: support for A51409
- Enocean: support for D21430
- Enocean: added battery level info to D21430
- Lutron: corrections for discovery, incomming msg handling and online status
- Lutron: correction for on-off switching of dimmers
- Knx: support BAOS830
- Camera: mangle url
- DSC: linked DSC users with BoxUsers
- DSC: various fixes for connecting to DSC through IP gateways
- DSC: always update sensors, handle emergency, fire, panic
- MQTT: create UUID on command event if it's null
- SIA: survive CSR sending lines terminated with 0x0d 0x00
- SIA: survive CSR sending ACK without #acct
