Firmware Version 0.9.999.6
Fixes:
- Z-Wave: added support for NOTIFICATION_SENSOR device
- Z-Wave: don't block non PING commands if device is OFFLINE
- Z-Wave: Added support for BarrierControl - Z-Wave: Better handling of GENERAL_PURPOSE alarm sensor event
- Z-Wave: Properly handle inverted state handling for ZD2102v2
- Z-Wave: Respond to BASIC_GET messages. Useful for Fibaro range detector and certain wall switches which poll device state before sending BASIC_SET
- Z-Wave: Properly handle BASIC_REPORT coming from SENSOR_BINARY device classes
- Z-Wave: Invert sensor state in ZD2102 custom handler
- Z-Wave: Nicer default device and endpoint names
- Z-Wave: Always send WNI encrypted if possible
- Z-Wave: Custom handling for Vision ZD2102 v2 door sensor
- Z-Wave: Added support for Cooper scene controller
- Z-Wave: alarm handling fixes
- Z-Wave: increase decryption queue size
- Z-Wave: properly handle scale bits in meter report V3
- Z-Wave: Set proper precision for Danfoss valves
- Z-Wave: workarounds for PSE02 siren
- Alarm: fixed false alarm after reboot on exit zone if armMode=ANY
- Alarm: tamper message not sent if tamperAlarmMode=DISABLED
- Alarm: panic message not sent if panicAlarmMode=DISABLED
- Alarm: safety zones assume ready when no state
- Alarm: squawking with sirens always end with silence
- Alarm: canceling exit timer on disarm
- Alarm: deleted double disarm on zones
- Alarm: safety zones always raeady
- Camera: added missin camera getters
- Camera: added support for HTTP Digest authorization
- Camera: added support for separate URLs for taking snapshot and getting the image
- KNX: added DPT type configuration
- KNX: added support for DPT 20.105 and 20.107 on Thermostat
- RF433: added ACM-LV24
- RF433: added COCO LWST-605
- RF433: telegesis support
- SIA: remove Sia network without reboot
- General: blinking LED fix
- Thermostat: added type field to Thermostat
- Thermostat: sending ThermostatMasterControl.value = (heating.target + cooling.target)/2
- ARW: battery status changed from from {100,-1} to {0,-1}
- Enocean: reduce timeout to 55 seconds.
- GenericIP: added polling for bulb status
- GenericIP: fixed Colour conversion from hue to the RGB
- GenericIP: fixed issues with the memory leak
- P1: decrease event count for frequent events
- Paradox: reimplemented discovery
