Fixes:
- Alarm: zone persistent state fixes
- Alarm: firing StateChangeEvents on PartitionControl after restore
- General: forced https connections
- General: http headers case sensitivity fix in local API
- General: fixed the use of content-length header in local API
- General: reboot no longer required after setting config on box with clear config
- General: added support for mdns discovery on multiple NIFs
- General: added support for multiple servers when connected to 3G backup
- General: added support for configuring NTP servers
- Z-Wave: clear association groups before settings associations
- Z-Wave: change AGI_GROUP_REPORT lsb byte to denote lifeline group
- Z-Wave: security handling fixes to tighten secure device handling
- Z-Wave: security fixes, add more keypress modes to ZwaveSceneInput
- Z-Wave: device configuration fixes&tweaks
- Z-Wave: fix device configuration wrong event name
- Z-Wave: fix alternate virtual node indexing
- Z-Wave: minor fixes on BarrierControl and ZwaveBarrierControl
- Z-Wave: minor ZwaveBarrier fixes
- Z-Wave: set specific and generic device class for sensor binary and alarm sensor endpoints
- Z-Wave: fixed invalid state value (0xFF) for levelcontrols
- Z-Wave: implement default configuration for CONTROLLER_SCENE_CONF command class
- Z-Wave: order of configuration fixed
- Z-Wave: disabled auto BASIC_SET redirection
- Z-Wave: do not increment SwitchMUltilevelReport 0.
- Z-Wave: increment special case value 99 from SwitchMultilevelReport
- Z-Wave: BASIC_SET handling fixes
- Z-Wave: assign proper node id for each association group
- Zigbee: ping every 30 seconds
- Zigbee: send battery status event after pairing
- Zigbee: bind to temp and hum sensors
- Zigbee: set trouble on device if trouble bit is set on zonestatus
- Zigbee: send identifyquery command instad off identify to check if device is alive to avoid device blinking
- Zigbee: add fahrenheit support for temperature
- Zigbee: remove pool control
- Zigbee: added TM attribute periodical querying
- Zigbee: added field for low battery message that can be seen via descriptors
- ARW: support for "Blue Comet" ARW radiator valve
- IP: updates for the way Philiphs Hue Bridge is being joined
- IP: improvements on issue handling with Philiphs Hue
- Camera: added wss-wssecurity authentication to Onvif discovery
- Upgrade: add GPG verify for Philio FW upgrade
Firmware Version 0.9.999.8
