Firmware Version 0.9.98
Features:
- RTSP streams from cameras
- support for local connection for Apps
- Bonjour discovery
- Z-Wave association
Fixes:
- Zwave - reworked adding/removing devices to network
- General - LED intensity reversed
- Thermostat - thermostat still running if turned off and output is On/Off switch
- KNX - devices not reloaded after discovery
- Alarm - users (other than master) got invalid PIN by default that couldn't be changed
- Alarm - if siren is added to squawks, siren's squawk function used
- Alarm - shutdown siren on disarm only if tripped
- Rules - time between block was using incorrect time zone
