Firmware Version 0.9.999
Features:
- General: changed LED pattern
- General: added UPNP discovery for cameras
- Alarm: added attributes arming and disarming to partition - these are set to true when exit/entry delay is active
- Thermostat: thermostat can be configured to be disabled when created
- Z-Wave: added Z=Wave plus compatibility
- Z-Wave: support for pending values - see values waiting for sleeping devices to wake-up
- EnOcean: added support for EnOcean
- Modbus: added support for Modbus
- Zigbee: added support for ZLL lamps (Osram fully supported)
- added support for Power, Security and P1 modules
Fixes:
- General: fixed memory leak caused by attributes from deleted devices
- General: fixed various issues with local mode API calls
- Alarm: fixed false alarm when sensor in arm mode ANY recovers from offline state
- Alarm: fixed entry/exit started event triggering email/SMS/call
- Alarm: fixed panic alarm always audible
- Alarm: disabled LED indications for mobility partitions<
- Thermostat: fixed rounding errors with conversion between Celsius and Fahrenheit
- Thermostat: fixes for using the same Z-wave THERMOSTAT_SETPOINT as input and output
- Thermostat: added sanity check for input values
- Thermostat: fixed running without thermometer input - only set points work
- RTSP Proxy: fixed crash caused by bandwidth too low
- Rules - fixed Basic Authentication problems for HTTP client
- Paradox: fixed recognizing Arm/Disarm special events
- Z-wave: fixed random deadlock issues
- IP camera - recheck net/mask before scan for cameras
- IP camera - aborting scans of large network
- Backup module - faster event processing
- Backup module - increased temperature precision
- Backup module - added adjusting shock sensitivity (delete device and Synchronize to apply changes)
