Firmware Version 0.9.999.1
Features:
- General: added static IP configuration
- General: added keepOnline parameter to prevent box from rebooting when disconnected from the cloud
- RF433: added Somfy RTS support
- RF433: added Vision 433Mhz sensors support
- RF433: added Kangtai support
- Alarm: added maintenance mode
- Groups: added support for setting attributes on groups
Fixes:
- General: added missing properties for API v2 discovery compatibility
- Alarm: restored mobility check
- Alarm: ready state of zones with armState ANY was not cleared on disarm
- Alarm: exit zone not working when armState of exit zone isn't ANY
- Alarm: current mobilityTime (set by scheduler) was overwritten with default mobilityTime after sync while partition armed
- Alarm: entry zones were not tripping if entryDelay was set to 0
- Alarm: entry zones were tripping instanly on successive trips
- Alarm: zones persist state across sync
- Alarm: added mobilityTripOnAway option
- Alarm: applying schedule immediately after sync
- Alarm: reinitializing zones after sync
- Alarm: tripping on tampered siren
- Thermostat: retry settings made configurable per endpoint
- Thermostat: vacationPreset if empty set to first of { VACATION, AWAY }
- Thermostat: added support for disabling the whole thermostat by enabled=false on MASTER endpoint
- Thermostat: ignoring thermostat setpoint inputs from devices while initializing, executing setPreset amd setMode
- IP camera: support for timed PTZ operations
- IP camera: fixed missing MAC address when discovery started with IP scan disabled
- IP camera: fixed rediscovery of deleted cameras
- IP camera: speedup - paralellized discovery
- IP camera: fixed initialization of IP devices with static IP and port number
- IP camera: fixes when using UPnP or Onvif to find changed camera IP address
- Scenes: in some cases reboot was required to change the scene
- Z-Wave: inclusion fixes
- Z-Wave: support for Z-Wave chip soft reboot after failed inclusion
- Z-Wave: sending device status update after join
- Zigbee: sending device status update after join
- RF433: improved X10 RF support
- RF433: improved 433MHz module range
- 3G backup: stop checking for IP gateway on 3G shutdown
