Component:
- Virtual thermostat
Process:
Configure Thermostat by its Scheduler, Devices, Modes and Configuration:
1 - Scheduler:
- Scheduler defines active Thermostat Modes during every weekday and holiday:
- to change Scheduler either click on scheduler bar or click Add icon at the lower right corner
2 - Devices:
- add or remove Thermostat device(s):
2A. Select Thermostat devices option
2B - to add new deivce click on Add "+" icon and select thermostat device from the list:
2C - to remove already added device, click on Delete icon
- If thermostat device is selected, Thermometer is defined by default and assigned to the selected Thermostat device(s).
3 - Modes:
- click on each Mode and define its heating/ cooling setpoints
- to confirm changes, clisk on Save icon
- to reset Modes to the defualt values click on icon at the upper left corner and confirm by Change button
4 - Configuration:
- define the following parameters:
- Temperature step - temperature step of termometer data
- Stage difference (if supported by Thermostat device) - diference at each stage (up to 3 heating and 2 cooling satges)
- Hysteresis - up to 2 degC
- Minimum/ Maximum setpoint - min/ max limits of the setpoint wheel
- Setpoint step - step of the setpoint wheel
- Difference between heat/cool - diiference in deg between heating and cooling setpoint
- Compressor protection delay (if supported by Thermostat device) - delay in seconds in starting compressors when changing between heating/ cooling modes
- O/B relay logic reverse (if supported by Thermostat device) - O/B terminals for heat pump systems and is used for the reversing valve. By default: O/B off for cooling
