Component:
- Virtual thermostat
Process:
NOTE: Virtual Thermostat2 PRO requires license and it doesn't require using of any Thermostat devices. All output heating/ cooling devices and Thermometer(s) can be defined by user.
1. Select "Devices" from the main menu
2. Open Virtual Server card under Server list:
3. Click Add ("+") icon at the lower right corner
4. Select "Virtual thermostat2 PRO" under adding virtual device selection menu:
5. Define Device name and select real Thermostat device already included into System:
6. Open Thermostat2 PRO Device widget:
7. Define settings of its ability - Name, assign to Room, hide from Dashboard
NOTE: Thermostat configuration settings can be check at https://community.zipato.com/agent/object/27217
