Security disarm in rule creator
I have a few problems with security widget.
I can arm/disarm without any problem alarm with web interface. (sometimes, it seems i need to synchronize, but it works most of time)It doesn't works with iphone app. I can watch if alarm is disarm, home et away but i can't change mode of working with button on iPhone.
On iPad arm, i can't enter my pin code (the '6' digit doesn't work)
last but not least, i have made a rule wich activate alarm every day à 07pm and another which disarm it à 07am. The alarm is well activated but never disarm. I have ever made a second rule at 07h30 am which disarm it once more, the result is the same.
update: even with manual disarm in web interface, i often have a disarm alarm on interface, but the alarm trigger if i open a door or activate a motion sensor.
I am definitely waiting for the disarm function in rule creator...a must have functionality as far as I am concerned.
PLEASE think again about this restriction ;)
I assume that it is for security reasons, but you could add an option in alarm's configuration to bypass it...
Thanks for your consideration and your work!
