Modbus support list
Jozef Humaj - Fixni.to shared this question 8 years ago
is there any official modbus devices support list?
thanks
Jozef
Modbus support is usually done on-demand / per project as it takes more time than supporting Z-Wave devices.We do have a lot of modbus devices supported already, if you would like to know about a specific device open up a ticket and ask - and we'll be sure to check it out.
Ok so i'm going to write script which will create a support ticket for every modbus device found :D
Or maybe, wait for it.... You can publish official support list like other companies do.
Jozef
3
Generic Modbus Meter
CoolMasterNet Device
Brink Flow Control
Brink Bypass Valve
Brink Set Control Mode
WB-MR14 Holdings 41
WB-MR14 Holding1 41
WB-MR14 Coils 41
Advantech ADAM 6015 Temperature Sensors
Advantech ADAM 6050 Outputs
Advantech ADAM 6050 Inputs 1
Advantech ADAM 6050 Inputs 2
WB-MR14 Coils 42
WB-MR14 Coils 43
WB-MR14 Coils 44
WB-MR14 Coils 45
WB-MR14 Coils 46
WB-MR14 Coils 47
WB-MR14 Holdings 42
WB-MR14 Holdings 43
WB-MR14 Holdings 44
WB-MR14 Holdings 45
WB-MR14 Holdings 46
WB-MR14 Holdings 47
WB-MR14 Holding1 42
WB-MR14 Holding1 43
WB-MR14 Holding1 44
WB-MR14 Holding1 45
WB-MR14 Holding1 46
WB-MR14 Holding1 47
SolarEdge Meter
BQ150 Coils
BQ150 Inputs
Siemens S7-1200 Meter
SolarLog INV Meter
SolarLog CON Meter
Siemens S7-1200 Holdings
X-300 Temperature Sensors
Siemens S7-1200 Holdings 5
Siemens S7-1200 Meter 1
Siemens S7-1200 Holdings 2
Siemens S7-1200 Holdings 3
Siemens S7-1200 Holdings 4
Siemens S7-1200 Holdings 1
KMTronic Relays
ET-7018Z DO
ET-7018Z AI
X-300 Thermostat
SHJelectronic S6133
SHJelectronic S6133 Select
BQ150 Inputs 1
VFACE Thermostat
VFACE Temperature Sensor
VFACE OnOff
E3/DC Meter
DRM88ER Relay Module
Have fun!
Thank you
When you try to add a ModBus device now, only one device appears, with no option to enter parameters manually. Something's been lost in one of the upgrades.
That wasn't so hard was it? Now where is the permant link on the support page menu for supported devices, searchable by protocol and manufacturer? Evidently you have lists, why not make them public.
