Vision shock sensor
Domodial shared this question 13 years ago
VISION SECURITY - Détecteur de choc Z-Wave ZS5101
Can you tell me when the shock sensor will be recognized by vision zipabox?
thank you
Replies (6)
Yes, the device work on shock (statut on red light) but not in Alarme section.
Have you news ?
  1. « Also i owe you an update for Vision shock sensor. As for now this device can only send alarm report when shock is applied. I am trying to negotiate with Vision to implement other report than only alarm, so it could be shown on dashboard. As alarm report for both, tamper and shock, so we can’t divide them. When I receive more information from Vision will inform you as well. »
The sensor is recognized by the Dashboard (red LED for a shock), but not in the security plugin. No alarm triggered.
New version Z-Wave+ apparently not well supported... Works in alarm partition section but not in rules creator. See attached image.
Was there found a solution in the meantime?
I've the same problem, i did not have any atributes in the rule creatur.
