Smoke sensors and the security partition?
Hi all
I have added four Fibaro Smoke sensors to my Zipatile setup.
Do I need to activate the Safety partion to make Zipatile react when smoke is detected - or does it always react to smoke"
... and do all four alarms go off if one of them detects smoke?
Thomas
Thomas,
I don't have Fibaro Smoke sensor but I have Zipato one and should be pretty much the same. There are several ways to integrate, how you do it depends on what are you trying to achieve.
* Integrated siren on smoke detector works regardless of the controller, it will go off as soon as it detects smoke.
* If you want Zipatile Virtual Alarm to react to it (whether you want to send notifications or trigger Tile' siren then you want to add a Safety Partition on the alarm, keep in mind safety partition are always active and will make every siren configured in the Alarm to go off (sound).
* You can also leave the smoke sensor out of virtual alarm and trigger any other siren or notification using rules.
* You can create direct associations between the smoke sensor and devices that support alarm messages and this would make them trigger in case smoke is detected.
Best Regards.
Thomas,
Best Regards.
