Fibaro Flood sensor
Hi Zipato,
I'm about to order the Fibaro Flood sensor. Is there full support?/are u working on it?
Thanks!
Oke great!
Oke great!
Oke, full support is there?
Look here:
http://maison-de-geek.com/2013/10/news-configuration-du-fibaro-flood-sensor-fgfs-101-avec-la-zipabox/
Can u confirm this Milan?
Look here:
I have one tested. Flood and tilt works fine but can't get temp meter to show
anything atm.
anything atm.
Hi Miro,
If you look at the link you also see no temp. So don't think this is working right.
Did you send an ticket to support about this? I'm about to order one to.
Hi Miro,
Hi HeroS.
All working fine now by default. Minor error was corected by support.
Fibaro flood sensor working just fine now. U can order one. :)
Hi HeroS.
Oke, great!
Thanks for the reply.
Oke, great!
Hi Miro,
got mine to. Very very very nice device. Whau, how same unbelievable.
Can you please show my your rules and config?
Hi Miro,
I also got one.
I must admit that it's a nice device.
I noticed some difference of temperature between this device and the everspring st814.The strange thing is that the difference is not the same when both are placed indoor and outdoor.
I will check this with a real thermometer this week end and maybe try to offset the temp settings.
I also got one.
Hi Thomas,
Can you show me your rules?
Hi Thomas,
Devices is going offline and to problems alot.
Do you have these problems to?
In the beginning yes!!
It was showing offline even with new battery.
The morning after, it was online and sending informations.
For the moment, I did not create any rules with that device...I'm first waiting to calibrate its temperature sensor.
But I just tried to create a rule with the sensor puzzle, and it doesn't allow to use the temperature/tilt sensor....only the flood sensor can be user within the rule.
By the way, I don't care about the tilt sensor...I see no use in my configuration.But anyway, the sensor isn't activated in the zipato dashboard.When the device is moved, it makes a sound, but no tilt state change in dashboard.Would it be possible to stop that sound by changing a parameter? I did not found which one to use.
Did not test it yet.
To disable sound:
To disable sound:
I'm stupid...I was using the same "flood detection" bloc... ;)
It's ok with temp meter.
Concerning the sound...I was thinking the setting your are showing was only for flood detection (alarm sound and visual alert when water is detected). Are you sure it does affect the motion sensor too?
I'm not at home right now so I cannot give it a try.
Good point.
Maybe this parameter:
74. Alarm frame sent to 2-nd Association Group activation
(MOVEMENT_TAMPER / BUTTON_TAMPER) (1 byte)
Available settings:
0 - tamper alarms inactive
1 - button tamper alarm active
2 - movement tamper alarm active
3 - button and movement tampers alarm active
Default setting: 2
Parameter size: 1 [byte]
The device is able to turn on alarms resulting from sensor’s vibrations e.g. when
the sensor is moved,
This is not the sound but the whole motion sensor. it don't see anything to only turn off the sound.
Good point.
Available settings:
Default setting: 2
I'll try this one...I don't need to get any notification when sensor is moved.
Thanks!
Thanks!
Yup it works.
No more sound when I move it ;)
Yup it works.
Oke great!
I accidentally turned on the Alarm Broadcast and my son lifted the Flood sensor. Then all my lights went on and off. LOL
I had to turn off the main power to make it stop.
Oke great!
Haha automation is still making us go crazy sometimes... ;)
Also i noticed that the motion (shock) is working with the Alarm Broadcast on but not working when it's off.
Going to send this to support.
groetjes,
Inkey
groetjes,
Inkey
Nee, niks meer van gehoord. Ik gebruik het toch niet dus ben er verder niet achter aangegaan.
