Parameter camera EDIMAX IC-3115W
Alain shared this question 12 years ago
I'm trying to install a Edimax IC-3115W camera.
When use Default Settings as proposed, I receive a fail:Failed to update settings on camera.Try to save again or update manually.
So can you tell me what I'm supposed to set as "Enter data from camera" ?
I tried a lot, but without success...
Many thanks in advance
Alain
@ Alain.
Have you solved this problem yet as I have the same problem.
Hi David,
Unfortunately not. But my camera was returned after a failed firmware upgrade!
So my problem disappeared with this...
But I would still appreciate an answer form support...
