New Aeon Home Energy Meter DSB28 problems
Kead shared this question 12 years ago
I have buy the new Aeon Home Energy Meter DSB28 with 3 clamps.
It's the Second Version of this product.
zipabox recognizes the product but does not work well.One of the camps returns values ​​impossible (like 23500w) and the other two clamps give too low values​​.There are compatibility issues recognized?How can I reset the values ​​of the product? Than the old version is not provided for this possibility in the CONFIGURATION.
I am experiencing exactly the same issues with completely wrong values on one of the three clamps.
I have tried with removing the device, then DELETING (this removes old data) it from the device tree in the dash board and then resetting and joining back the meter but it seems to always START with a completely wrong (and too high) value.
See attached screenshot.
After some Google-use I have been able to find out that it seems to be a problem with some changed configuration parameters in version 2 of the meter compared to the first one which was powered by batteries or USB.
Doc for first edition: http://ozw.my-ho.st/Aeon/Engineering%20Spec%20-%20Aeon%20Labs%20Home%20Energy%20Meter.pdf
Doc for 2nd edition: http://ozw.my-ho.st/Aeon/Engineering%20Spec%20-%20Aeon%20Labs%20Home%20Energy%20Meter%282nd%20Edition%29.pdf
At http://forum.micasaverde.com/index.php?topic=14821.0;nowap they discuss the same issues... as well as here http://forum.fibaro.com/viewtopic.php?t=3275&highlight=energy+meter and some examples of proper parameters at http://forum.fibaro.com/viewtopic.php?t=3212&highlight=energy+meter
Please, both of the device reset the measured values. I do not want to reset the entire device.
did you both get this working with Zipabox now?
Please give me an update.
Thank you.
Beat
I'd also appreciate your feedback! Thanks!!
