Reset mulitsensor
Steven Curren shared this question 6 years ago
I have a ZIPATO multisensor 4 in 1. I am unable to have it join my z-wave network. Is there a way to factory reset this device.
Thank you.
I have a lot of these devices. The trick is you have to click the include button very very quickly 3 times. For a reset you have to click the button 3 times fast and then you click the button within 1 second a 4th time. The 4th time you have to hold the button more then 5 secounds.
Thanks, I'll give that a try.
Hi guys i hope the inclusion had worked... Do you have thes device (4 in 1) with door sensor humidity and temp...
I had to reset the dvice and icluding it to fibaro home center.
10 times in 10 seconds....nothing works..
do you have any advices ?
8541ea27fdb5fa7937894e5d2a5f01af
A reset is not necessary! Go to exclude in the Homecenter, then tap the button three times quickly. Exclude is confirmed. Now immediately start Include in the Homecenter and do nothing else! The sensor automatically goes into including after the exclude! DON'T press the Button!
