How to remove room in widget drop down menu
Guest shared this question 13 years ago
I was using the dashboard in english with sensor associated a room in english.
Then I switched to italian, and I choosed the room in italian fro every sensor.
Now In the widget drop down menu there are both italian and english room.
How can I delete the unused room in that menu?
See picture attached,
thank you
Currently there is no possibility to delete or rename room.
It will be possible with new widget that we are working on.
Replies (22)
When will it be possible or delete an empty room?
Thanks,
Philippe
5
So, after 8 months, how toremove rooms?
After 11 months no action?
Any update of this question?
Not yet. Will be published in August.
Hi Sebastian, so is there an update on :
a) Removal of rooms
b) Renaming of rooms
I am writing this at the end of September 2014
a) Removal of rooms
They are working on new UI, i think they will publish it very soon. I hope new UI will clear this problem.
Me to...
Removal of room please.....
Any update to fix the problem ?
Use API it works nice for all aspects
Once it is empty, room will dissapear automatically.
It doesnt work for me. I still have empty rooms in my list.
ok i have a virutel weather station and it can not assign a room.
hi
how to delete the rooms using the api
ZIPATO team?
There are some news? I accidentally created two rooms of the same name , I would eliminate one of these
Just use the API to remove it.
How do you do that?
-Click on the top of Dashboard to API
-go to rooms
-first "get" rooms
-now you have the ID from the room, you want to delete
-last, "delete" rooms(room)
regards Maik
or simply you can remove all devices from the room and it will be deleted by it self
Still no way to edit or erase the name of a room? That would really be handy!
Same question...
Try via the android app or on zipatile
It´s possible to delete a room in the API.
