Connection between IPX800 and Zipabox
Matthieu A. shared this question 12 years ago
I try to connect my IPX800 to my Zipabox. I want to use the command "request socket" for sending the command << TCP>> <<IP>> <<port>> <<command>>. but is not functioning! I tried directly from an other TCP client and is ok! Somebody as an idea?
I want also try to read the input from IPX but i have not the necessary space to put the link (Zipato link for virtual meter) is too long? it is possible to read the status by using request socket from Zipato? from other program is ok?
Replies (7)
did you try using the SEND HTTP puzzle?
Yes is working. But i don't understand why the socket command is not working?
It's possible to get value true the socket ?
Actually, the socket request function can not be used with zipabox, it won't work.
I asked about this functionality when I bought a relay card controlled by socket request only and I had to replace it by an ipx800 (to control it by http requests).
Ok... bad news i hop this function will be soon implement. this can be a very good tools if is possible to send en receive command by socket . i think is already working with the home center from fibaro!
Yes it is working with HC2.
I hope this function will be implemented too.
Just confirmation that we have it on the road map...
3
