Climate (Endpoint) Widget events usage in rules
Theo van den Dolder shared this question 12 years ago
In the event list I see the following events:
Keuken_HEATING STATE true (when widget starts and indicates Heating)
Keuken_HEATING STATE false (when widget stops Heating)
Is there a way to use these values/states in the rule creator?
They are not available as options when i place the thermostat as sensor in the rule creator.
Theo,
I am also interested with setting thermostat states in rules. did you get an answer to your question or find a way to use rules to set your thermostat state ?
The thermostat value HEATING STATE can't be used in rules.
To use the heatings status I created a virtual switch. This switch is set as output device in the thermostat.
The virtual switch status changes when the thermostat start heating. The virtual switch can be used in rules as trigger.
