Mqtt no connection
In Progress
Hi I have successfully set up the mqtt network on zipabox. After some days I changed the broker ip from ip to hostname with the rest api and I cannot see anymore the box mqtt topics.
I tried to put the ip back but still no topics. I tried to remove the mqtt network but it seems impossible and I tried to reboot the zipabox.
Do you have any other advice? Is there a way to check the mqtt errors or system log?
Perhaps you can publish your mqtt configuration here (from the api) because it should work (hostname)
Hi, thanks for you replay.
I managed by adding a new mqtt network with hostname which has deleted the previous one and start to work.
thanks for your time
Hey John, Riccardo
as I still have problems to get the mqtt working I am highly interested in your solution. What means "hostname"? Does it mean not to address
but to use eg. TCP://openhab:1883 ? And, Riccardo, how did you manage to delete the privious, not working mqtt network? Please let me have a more detailled description of what you did.Thanks
Bernd
Hey John, Riccardo
Bernd
