Zipabox stop reading data from Oregon THGR810
In Progress
I recently got a Zipabox with built in 433 module. To test climate control (my main intended use for the system) I use an Oregon THGR810 as input and wall plug as end point for control of one room. I also have another Oregon THGR810 to read outdoor temp (no control).
Two times during the last month Zipabox has stopped reading data form both Oregon sensors for no apparent reason. This is not due to poor signal, the sensors are close (2-5 meters) - and checking logs of sensors revealed that data was lost at the same time from both Oregons. On both occasions a reboot solved the problem, but this is of course no long term solution.
What can be the reason for this unstable performance which makes the system unreliable for climate control?
please contact us on support@zipato.com with your user credentials and we will resolve your problem.
Thanks for a quick reply!
Will send you info
All the best, Mats
Will send you info
All the best, Mats
I experience similar problem.
