Support for Sunrichers zwave LED-drivers?
Hi.
Have anyone successfully added any of Sunrichers zwave supported LED-drivers, or is there any information if/how they are supported on the Zipato platform?
Regards// LH
We have supported some Sunricher devices so if you found a particular driver send the model name and I will check if we have it in the database.
Hi Ivan.
That sounds promising. The drivers in question all have the same name, SRP-ZV9105-XXCC, where XX is replaced with the maximum watt.
Regards// LH
Hi Ivan.
Regards// LH
Currently we only support the SR-ZV9105 single color dimmer. When a device is not supported you can still add it to your Zipato controller and it will get a generic descriptor. We extract the relevant data from the inclusion process to create a tailored descriptor for the device that contains Zwave configuration parameters from the device manual and necessary data so you can control the device via the web or the mobile widget. In other words you can add SRP-ZV9105 to your Zipato controller and then submit a ticket saying the device isn't supported yet. We'll make the necessary configuration for it.
Thank you, much obliged.
