rule sync failure
Nico Peirs shared this idea 4 years ago
Since yesterday I get an error syncing my rules.
I use V2 with zipabox,
I know it is not supported anymore, but I don't want to pay over 500€ just to keep it running.
However this issue gives a great disavantage, I hope it is only temporary.
Anyone else having same problems ?
Replies (9)
It's the same problem for me. Please ...
It's OK today !
No nothing is working
Is working here since this morning. I hope it stays this way :-)
Rule sync failure 07/05/2022 ...
SYNCHRONIZATION ALWAYS FAILED ...
Synchronization not possible.
However, access to the box is possible via the application.
We can not add a new component because the synchronization is no longer done.
Please, could you give me a solution ?
Bests regards.
Luc Edel
Last time it die not work for about a week. Lets hope its only temporary.
It's Ok Today !
Impossible for me to synchronyze since last Friday May 6th.
At the begining, the box was not connected to the server (green light blinking). Now the green light is fixed
I've restarted several times the box and it's still not able to synchronize rules.
And till now no rules are working from my side.
Note : I'm currently using V2 with last version 1.2.41.
When this server sync issue will be fixed ?
