How associate scene to button on AEON Keyfob 4 buttons
christophe92 shared this question 13 years ago
Hello
I have a AEON Keyfob 4 buttons. The current firmware version of my zipabox is 0.9.961.
I have joined sucessful the keyfob. But now, i don't know how associate a scene to a button on Keyfob.
The status of each button is "SCENE_MODE" and the wake interval is 5 on the configuration IHM. But on the IHM of the endpoint, "Bindings" is empty. Could you help me??
Replies (16)
You need to create a rule for that. See example in attachment.
OK, thank for the rule, i do it but how to associate to the keyfob ?
What do you mean by "associate"?
I think the example is clear, when you press button on keyfob some actions are going to be executed (run scene in example).
Yes, the example is clear, i do that to run a scene (the scene run well with the dasboard), but i press button it doesn't work. Why? what can i verify to known if the keyfob is ok, On the dashboard the device is active, the endpoint is active, but the ihm bindings is empty
I tried again this morning : delete the device, reset the device (reset
ok), join the device (join ok), create and synchronise a rule to run
scene when i click on button 1, BUT it doesn't work
device = Aeon Labs Key Fob
I think that the device is in the right mode : if i click on the button 1 (or 2,3,4) the led is red, i press the button while 1 s, the led is flashing green.
I make a simple rule : click button 1 set value 100 on my lamp
but it doesn't work
no fix red
the red flashing to the right button once is on setup mode. I change mode
how can know the right mode on keyfob?
I tried, for me there is 2 modes :
first mode = setup mode, button 1 = include (green led flashing), button 2 = exclude (red led flashing), button 4 = learn (green led flashing)
second mode = group/scene mode, just a clic on each button you have red led, if press each button you a green led then if press a long time the green led flash
My keyfob is on the second mode, i think that is the good mode and when press button my rule doesn't work, no event in the dashboard
I'm surprise, if i remove the battery, the device is always online on the dasboard ! When you put again the battery, the keyfob is on setup mode.
thank for your help, i'm waiting news
News ??
Hello all
I try to add a 4 buttons Aeon Keyfob.
I follow instruction, good until number 3, but never succeed to join device.
Zipobox never found device to add, but found device to reset or remove.
best regards
I tried procedure describen by Millan and later on create a rule to light on a lamp with 1 botton and workd fine
More test to come but it seems to work fine on 0.987 firmware
Hi, i have also a problem with this keyfob. I joined the device : it's ok but impossible to manage the keyfob. The keyfob is always offline in the dasboard. Why?
