On and off in one rule
Torbjorn Nesheim shared this question 11 years ago
I'd like to be able to set an explisit on-time and off-time on within one rule, eg
time=17:00 -> turn on
time=23:00 -> turn off
Any suggestions how to do this? I've tried to search this forum without any luck, but my search strings might be the problem...
This function can be implemented by using two rules but that I already know. I also do not want to use the wait-command.
You can try something like that:
XF738Eco0XuannRmJhnB
The scheduler is "Minutelly", every 1 minute.
I also use this kind of trick to call an URL on Virtual Device Change :
ZCVDxvRjRrtouth5MuFb
Thanks! Of course, the timer is very versatile, and I didn't think of that approach.
You can use two schedulers in one rule as trigger.
Try.
When Sched1 (7.30) or Sched2 (23.00)
if light=on
light set to off
else
light set to on
OR
if time(now) = 7.30
light set to on
if time(now) =23.00
light set to off.
Problem is, if your box or device is offline at the precise moment of the trigger (murphy's law), action is never performed.
