Ctronics Camera no stream accepted working streams in vlc
i´m using an ctronics camera Model: 380C-4MP (C6F0SoZ0N0PfL2 )
In VLC I can see the rtsp stream by using this URL: rtsp://ip-adress:554/ or this URL: rtsp://usrname:passwd@ip-adress:554/11 both are workin perfect in VLC.
When i copy this URL in the camera settings i get an failed to load stream data.
In the admin section i entered admin and passwd. No change!
The same with onvif..... took this URL: http://ip-adress:8080/onvif/device_service (works perfect in ispy) but not in zipato...
Whats wrong with that?
I have same with new foscam cameras.
Link works well in vlc but not in Zipatile envirement
Thanks for sharing, I found a lot of interesting information here. A really good post, very thankful and helpful that you will write many more posts like this one.
