Control center don't keep right time zone. Not solved!
Jki shared this problem 11 years ago
As earlier. A bit later all events are one huor ahead.
_hour_... sorry.
I presume you have checked the time zone information on your Zipabox under General Settings?
If so and it is not solved, open a ticket with support@zipato.com. I had the same issue logging events and they fixed it remotely for me.
/Marcus
Yes, time zone is checked. The problem is, that the zone changing one hour ahead, when control center is open a bit longer. Ie. when I logged in, and check events, if there is like some last temp reading made 20:43, then some time later the same reading is made 21:43. And local time is not yet 21:43.
