software development lifecycle
The software development lifecycle (SDLC) is a process for producing software that consists of a series of phases. The phases typically include planning, design, development, testing, deployment, and maintenance. The process of moving from one phase to the next is often referred to as "advancing through the lifecycle." The specific steps and activities that take place within each phase may vary depending on the specific SDLC model being used. Some common SDLC models include the waterfall model, the agile model, and the spiral model.
Any software developer should understand and understand the stages of the software life cycle.The software life cycle has several stages: coding,testing analyzing.Each stage of the software life cycle is very important.Each company has its own different directions in software
exactly as you are proposing it yourself, the program development life cycle is divided into several phases, it is a fairly complex subject, if you are not a person involved in this subject you will not understand much and doing it yourself would be crazy without No study or experience, so in cases like this, if a service like this type is needed, it will always be the most advisable to hire professionals such as these here https://www.dataart.com/
Yes, I largely agree that you need to have basic programming skills in various phyton and Java languages to implement software.These are the most important basic languages to provide.Anyway, you can't do it alone, or find a mentor at that link you were advised.I went to that link, by the way, learned a lot about software life cycles.Thanks for the information 🙌
