Adding Nexa WTE-2
Torbjorn Nesheim shared this question 11 years ago
I have a few Nexa WTE-2 double wall switches. This device is currently not supported by Zipato, but there are some suggestions of a workaround. I have not been able to add the WTE-2 following these instructions(and many other options).
Have anybody been sucessful in adding the Nexa WTE-2? If som please tell me how.
No but I hope every day!
*bump*
Someone found a solution?
The device is supported,You only need to upgrade to latest 8k FW.
I can confirm this!
But it is only WTE-2 not 1, WT-1 and WT-2
It not only works! It worked fantastically good, better then Tellstick NET!
It is less then 1 second respons time.
It is amazing how fast your opinion about Zipato can change, when things work and there is development.
Bigg thank you Zipato.
Have you tried to add 1-way wall switch you have as WST-916 and 2-way as WTE-2?
It might work, but no guaranties.
