Dimmer issue
Babazorka shared this question 11 years ago
Hi!
Have a qubino dimmer that do not work as supposed.
I can dim from PC/phone etc but cannot turn on off lights nor dim from push button.
Wiring is OK and the push button is srpring button.
Maybe i missed some settings???
thanks
Replies (6)
Spring button = Puls switch?
Usual NO push button with spring
tomorrow ill check wiring again maybe i have bad contact
In the past I read that the push button of quebino has to switch from the neutral (blue or red in europe) and not from the phase (brown or green). This is not the standard way to connect switches.
Yup, Anjos is right.
But i don't think a normal switch is going to work. With the dimmer you must use a push switch.
Qubino inputs seems be very sensitive and high impedance, so even small small current leakage in switch circuit can act like switch is always pushed (on). Finger between wires do also contact enough.
OK got it!
When i did inclusion of dimmer i used Service button istead of 3 click on push button.
I did new inclusion with 3 clicks on push button and it worked.
