Duplicate virtual devices
Pascal Verstappen shared this problem 11 years ago
Most, if not all, of my Virtual Devices are duplicated in the NEW interface, although they do have different UUIDs.
I have checked the same devices in the old interface and that only shows one of them.
What is going wrong here? Can I delete the duplicate ones without having to rewrite a whole of rules?
Thx
Pascal
What i remember is that if you look at those virtual devices the one that can be deleted does NOT have an endpoint. I found this issue quite some time ago and i deleted all the devices with no endpoint if i remember well.
Good luck
Thx - I have deleted some, however the issue seems to be bigger... Devices appear 3+ times in the Device-manager and sometimes only once. The funny thing is that de devices that appear only once, appear multiple times in te 'Lights & Power' section for instance.
Additionally the names of ''values" within the meters have disappeared. I cannot use the meters in the rule-creator. When I'm using the old interface everything is fine (I can also use the meters).
Any suggestion?
Thx
Pascal.
