Lighting rule makes motion sensor not responding (marked as problem)
Boyan Krastev shared this question 11 years ago
I have a problem with relatively simple rule for my bedroom lights.
Bedroom+lights+rule+makes+motion+sensor+not+responding
The idea is that between 08:00 and 21:00 when luminance is below 50 lux turn on dual light on ceiling.
Of course when motion is detected.
If there's no motion... then turn off all lights in bedroom (the time doesn't matter for off command).
Motion/luminance sensor is Fibaro FGMS-001 and switch module is Zipato MM (or Philio) 2x1.5kW
Rule runs ok when motion is detected and lights go on.
The problem is that motion sensor never reports "no motion" or anything else... lights go on forever and in some time
the fibaro multisensor is marked as problematic in device manager.
As soon as I disable the rule and sync... everything is ok and sensor reports everything fine.
Tried removing/adding the sensor... changing batteries.. even tried another sensor (swapped them from kids room).
Anybody has idea?
Thanks,
Boyan
