SOMFY portal motor integration?
Pat@ shared this question 11 years ago
the portal motors SOMFY RTS (ex. Evolia 400, SGA 6000) are integrated in the zipabox like the roller shutter?
I bought finally a SOMFY Evolia 400 portal motor. Is somebody has integrated this motor with a zipabox directly in RTS mode like roller shutter, is it possible?
Bonjour.
Quelqu'un a-t-il déjà domotiser un portail Somfy Freevia 600? Je suis super novice en domotique! J'avoue que je suis un peu largué.
Merci beaucoup pour vos réponses.
Seb
I bought a SOMFY Freevia 600 portal motor. Is somebody has integrated this motor with a zipabox directly in RTS mode like roller shutter?
Thanks for your answers ;-)
Seb
I have a SGS600 from somfy. Forget the RTS
technologie, because you need the RTS module and I think it work only with some
limited equiipment (rolling shutter)
The best way is to use this new module (available
soon):
QUBINO "Flush 1D relay" ZMNHAD1, you can
connect the free potential contact to the "switch" Input of the Somfy electronic
board.
Thank you very much Gizmodu74. It's Kind of you.
De rien Seb ;-)
