Getting signal from KNX moving sensor to Zipabox
Sergey N. shared this problem 10 years ago
Hello, does anybody try to make common net KNX and Zipabox? I experienced of running KNX devices by z-wave's moving detector and door detector with good result through Zipabox. They work very well. But I stuck with problem of getting signal from KNX moving detector to Zipabox.
My KNX's moving sensor sends 1-bit signal, but new added to dashboard of Zipabox KNX sensor doesnt work. It has still been INACTIVE and doesnt act on any signal from KNX net. I have done next actions:
1. In ETS I had added the new group address where I put down 1-bit signal from KNX moving device when it is moving on.
3ff3167bd24b06b9efba0a7c9f1c1c9c
2. In BAOS device I added new object and connected it with one.
a5dfc370dff6a61e237806eb4b0b3050
3. Then I used Zipato KNX import tool and imported moving group address to Zipabox.
e87f269a5b4cbdb879550dbc539ab3a6
3. In Zipabox I registered new KNX sensor and connect it with 1-bit moving group address.
5e073865892b8a9b7eb80b75a7623168
Then I sincronize system and my new ZIPATO's KNX moving sensor has still had INACTIVE status and doesnt react on any signal from KNX net.
7bb418cde43b3aa2d5859024042d4b35
Any body could advice me what I did wrong?
Oldest
  • Oldest
  • Newest
Replies (8)
For me the same problem!
Was für eine Zipabox Firmware habt Ihr drauf geht nur noch mit der 1.0.17
wo finde ich die Seriennummer
Die Firmware auf der Zipabox
Dann geht es nicht geht nur noch bis 1.0.17 das war die letzte funktionierende Firmware mit KNX.
warum denn das?
das Schalten von KNX funktioniert super, nur die Sensordaten werden nicht übertragen...
