Need help with a rule
johannes helje shared this idea 10 years ago
Hi!
I need help creating two rules.
The first is for a switch.
I want it to run a scene turning ON all the lights in the apartment if ALL lights are OFF or turn OFF all the lights in the apartment if there is one or more lights ON. I've tried making a rule with a variable sensing if the switch is off or on, but because it's a bipole switch that only works have of the time. If there's some lights on, it turnes them off, but sometimes it just runs the scene and then I have to flip the switch again to turn off all the lights.
The second rule is a simple coffee machine timer. I have a switch that I want to switch off 2 hours after I switched it on.
I've attached the current rule.
