Some New Suggestion
Mojtaba Shiroei shared this idea 10 years ago
Hello Zipato Team
I am a reseller and distributor of Z-wave
technology in my area.
I started our work with Fibaro HCL & Zipabox
and I found Zipabox technically more powerfull.
However, there are some deficiencies about
zipabox that i really want to be improved.
1- The Android and iOS application should be
more beatiful and briliant. In adition the application on iPad doesn't work
well anymore. Zipato has many technical advantages with respecto to Fibaro HCL
& HC2, but your UI is not attractive.
Recently you improved your web interface. It
should be done for iOS and Android too.
2- It should be possible to control and create
the rule & scenario in Zipabox locally from the PC. For example using a
seperate application software.
3- It will be very attractive to control the
zipabox and recieve reports from it using sms without the connection to
internet. Many of our costumer request sms control & reporting. These
feature bold security functions of your zipabox.
4- Please add saving user name & pasword on
your iOS & android apllication. Any time i want to enter my application i
should enter my user name and password. It is boring for me to do it several
times on a day!
5- Some times after minimizing my android app,
the application does the command with delay. To solve this problem, i exit from
app and then go to it by re-entering user name and password! You should
fix this problem.
and finally:
Wishing you all the best for 2015.
Mojtaba
