Offset value for temp and humidity
A little value for all temp/humidity devices to have an offset value. This should be an easy thing to programming and would be a big help for all people with devices that dosn't support this.
This would be really nice since most cheaper temp are measuring wrong (real instrument 1500 euro plus)
The good thing with cheep ones is however that they usually measure contently wrong so if offset can be set you can get really nice and correct readings with multi sensors like fibaro and others
Should be fairly easy to implement, aim already using this but in imperihome app. But would be nice to have it on controller instead
